The NARDI Cornwall
Watches and such at Kickstarter.
The NARDI Cornwall
Post by koimaster » January 27th 2020, 11:36am
So when we launch, there will be three variants, but all will share the same basic foundations.
The most important thing to note, is the steel from which our pieces will be made. If we’ve done our jobs properly you’ll already know, but for those who have just happened upon this article, all of the watch cases are being crafted from steel that has been reclaimed from the Royal Navy’s famous Type 22 frigate; The HMS Cornwall.
Standard Specification
Case: HY-80 Reclaimed Steel
Diameter: 42mm
Height: 13.5mm
Lug to lug: 50mm
Movement: Sellita SW200-1.
Glass: Double domed AR coated Sapphire Crystal
Bezel Insert: Zirconia Ceramic, Embossed with Bicolour printing and lumed pip
Screw Down Crown
200m WR
https://www.kickstarter.com/projects/na ... ject_build
https://www.nardiwatches.com/the-watch/
Return to “Kickstarter/Crowd Funding Projects”
