Breitling Part number and serial number system
Post by koimaster » March 26th 2019, 12:03pm
Breitling Watches 1944 to 1978
All breitling watches of this period have two numbers :
a Part number designating the model and a serial number
The part number is always located at the back of the case, for Navitimers it is a 3 or 4 digit number
Hre is a little list of Navitimer part numbers and their model (see the 50 year section for details and pictures of the models) :
806 : The first Navitimer, Venus 178 movement (and some very rare Valjoux 72) cover generation I, II, III, IV and V
7806 : The navitimer with date , Valjoux 7740 movement, Generation VI
7806-S : Navitimer with date and two subdials, Valjoux 7740 : generation VII
816 : Navitimer "big case", Venus 178 : generation VIII
1806 : Navitimer Chronomatic : Breitling 11 or 12 : genreration IX
8806 : Navitimer Chronomatic "small case" : Breitling type 12 : generation X
9106 : Navitimer LED quartz large case : generation XI
9406 : Navitimer LCD quartz small case : generation XII
9416 : Navitimer LCD quartz big case : generation XIII
Serial number of Breitling chronographs and non-chronographs watches from 1944 to 1978
Here is the list of serial numbers of Breitlings (all types not only Navitimers) with the date of manufacturing
Breitling Watches 1978 - today
After Ernest Schneider took over the Breitling company, a complete change have been done to the part number and serial number system
The part number system remain for a period similar to the pre-78 system and the last Navitimer to have a "pre-78" P/N is the Navitimer 81610 : the first Navitimer with the Valjoux 7750
Here are the two Navitimers which keep the "pre-78" system :
81600 : Navitimer tricompax no date, Lemania 1872 : generation XIV
81610 : Navitimer 3 subdials with date , Valjoux 7750 , genreration XV
Then Breitling switch to a brand new system still in use for the part numbers :
This new system is composed of one letter followed by 5 digits : type : A 00000
The letter designate the material of the watch :
A : All stainless steel
B : Stainless steel and gold bicolour models.
D : Stainless steel and gold gold/18k models.
E : All titanium
F : Titanium and gold
H : Rose gold
J : White gold
K : Yellow gold
L : Platinum
The two first digits designate the Breitling caliber used in the watch :
13 : Breitling type 13 (Valjoux 7750) .....
You can find Caliber type 13, 29, 30, 35, 39, 40, 41 ... in Navitimers
The Third digit designate if the watch is or is not COSC certified
0 : Non COSC movement
3 : COSC certified movement
The two las digits .... seems to be random ! in fact of course it is not, but the logic if fairly tricky to undersand : let us say that using the caliber number and the last
two digits, the model can be determined
Exemples for Navitimers :
A13019 : Old Navitimer, steel, (non COSC)
A13020 : Old Navitimer II, steel (non COSC)
A13320 : Old Navitimer II, steel COSC certified
D30022 : Navitimer 92, Steel and Gold (non COSC)
K13020 : Old Navitimer II, Gold (non COSC)
Serial numbers of watches post 1978
A serial number is assigned for each type of part number (not like ther old system where all Breitlings had a sequencial number) , therefore it is NOT possible to certainly date a Breitling modern watch with its serial number. this number is generally a 4 digits number (exeption for gold or limited series)
Return to “Breitling”
