- koimaster (Online)
Android Men's Divemaster Espionage 2 Compared to Citizen Promaster Eco-Drive
Thought I would buy this android for two reasons, one was to compare it to the Citizen I recently was given as a gift size wise and the second as a way to have someone donate money for the watch to a charity in Carols' name. First things first. This watch was $79.00 via groupon which is selling it a bit below the low of $109 I have seen and $200 plus. It is a very heavy watch even with the rubber strap. Not for the weak of wrist. Lume does not compare to the Promaster but I did not expect it to. Bezel was tight, not my favorite style but was not going to keep it anyway. Not a fan of the sunray dial but many are. Black pvd is ok, not certain how scratch proof it would be. It does show up brightly in the water. There, done. Now to the other part of this. I have done this before and it worked out well so time to do it again.
I pay shipping costs but you donate $100.00 to either charity below in memory of my wife Carol ( her birthday is coming up ) and you get the Android, a tax write-off ( the donation is yours, not mine ) and a charity gets some money to do something good. Tomorrow I will put up a Jacque Lemans Dive watch with the SW 200 in it for a $125.00 donation once again to either of the charities below in Carols' name.
http://www.arborday.org/canvas/?type=TIM&host=W&quantity=20
https://community.lymphoma.org/donatenow
•Men’s analog watches
•Wave pattern designed dial
•120 teeth turning uni-directional bezel
•Super luminova hour and minute hands
•Red AD second hand
•Luminous shape hour markers
•Stick minute markers
•24 hour indicators on inside of dial
•316L stainless steel case
•Case dimensions: 50mm (L) x 50mm (W) x 18mm (H)
•Band material: rubber
•Band dimensions: 10” (L) x 24mm (W)
•Buckle clasp
•Bezel material: IP stainless steel
•Bezel color: IP black
•Movement: Seagull TY2806 automatic movement with 21 jewels
•Pressure release valve
•Water resistant to 50 ATM
Vs
Black, textured dial with silver-tone hands and markers, blue accents
Black ion-plated case
ISO certified
180 day power reserve when fully charged
Solar powered so you never have to worry about replacing the battery
Black rubber strap
Date window at the 3 o'clock position
Screw-back case and screw-down crown
One-way rotating elapsed-time bezel
Non-reflective, mineral glass crystal
Luminous hands and markers
Water resistant to 300 meters (990 feet)
Case width 47mm
•Red AD second hand
•Buckle clasp
Vs
ISO certified
Black rubber strap
Case width 47mm
