Orient Star Royal--Impressions and Pics
Post by conjurer » November 6th 2017, 3:50pm
Normally, I don't bother reviewing a watch that's been discontinued for a decade, and I'm not going to do a full review of this one, either, apart from posting some pics and impressions:
Starting with the dial--it's beautiful, even in my substandard picture; the center has a very subtle texture, the chapter ring is smooth, and the seconds track has a different texture from the center. Taken together, it gives an impression of depth to an otherwise flat dial. The markers are diamond cut, to reflect light, which, along with the printing on the dial and polished handset, makes everything look a little more luxurious than a standard OS:
Interestingly, the usual power reserve arc is raised above the dial, and there is some sort of polishing/diamond cutting going on, because it reflects strong light back like a prism, showing different colors (which I was unable to get a pic of):
The crystal is very much like the newer OS crystals, with some sort of high-quality coating--it appears almost invisible, with just slight flares of reflection, particularly in sunlight.
One nice thing about the movement (I'm not sure of the caliber number) is that the date in the date window sits up a little higher than some other OSs and Orients; with some, it seems like you're looking into a hole to see the date wheel, which is set deep.
The movement itself is somewhat unique, in that, while not handwindable, it still hacks, allowing the user to set the time precisely. The movement is very accurate; the tolerances for Royals are -5-+10 seconds a day, and this watch is running almost dead on, perhaps gaining a second overnight, resting off the wrist dial up. Since I got it, five or six days ago, it's about two seconds fast in that time.
The case is a big step up from the standard Orient models, and a little better than the OSs I've owned. The polishing is very fine, the lines razor sharp, and pretty close to the finishing I saw on Hawk's Grand Seikos at the last GTG:
Another interesting thing is the oyster-like caseback with beaded decoration. Even though the crown doesn't screw down Orient still claims 100m of water resistance. Measurements of the case are a tad over 36mm across, 39mm with crown, 44mm lug to lug, and somewhat surprisingly, about 13.5mm thick. Lug width is 19mm, tapering down to 17mm at the clasp.
The bracelet is a pretty standard OS type, with solid endlinks and half links, which is the first time I've seen these on any Orient or OS. One of the things that show a lot of thought and engineering is the clasp, which has beveled edges on the inside for wearing comfort:
This watch, when new in circa 2005, would have cost about $1600 US. To me, this would have been worth it; this watch is and does what an expensive watch should do. It looks great, it wears perfect, and keeps outstanding time. It would be a fine watch for a guy who has to dress well for work to wear every day, even somebody who doesn't care about watches--it's practically the Rolex Datejust of Japan.
Mortuus Fakeuus
Re: Orient Star Royal--Impressions and Pics
Post by Mortuus Fakeuus » November 6th 2017, 4:36pm
"DIBS"*
*EyE really lykes me this'n, Conjurer, and eYe'm thuroughly hoaping you'll git reel tyred of it an wanna sellit directly tummy, ass andre Griffith wood'uh said tuh Borney Fyfendrumcorps own his TV show...halfuh nyce day-O...!
Post by conjurer » November 7th 2017, 8:04pm
Thanks for the kind words, all! Interestingly, for a pretty small watch, it wears more like a 38-40mm; I guess because of the case thickness, and the somewhat minimal bezel. Also interesting is the bracelet, unlike newer OS's, uses simple friction pins. The more modern OS's use a collar in the center link, very similar to some Omegas.
Post by tiktok » November 7th 2017, 8:45pm
Keep an eye on Zenmarket.co.jp for lightly used Orient, Seiko and Credor affordables from the turn of the century. I think Big Lug got a GS somewhere in there. They have links to other auctions like Rakuten which tends to have newer stuff.
Post by 3Flushes » November 7th 2017, 11:42pm
I like it, I like it a lot! I hope you wear it on the next trip to the PB's- would love to see that baby up close and in personal, and, you know how I love the Hot Toddies with the turbinado sugar and the cloves, and the Dead Rabbit Irish Coffees with the Jameson, Demerara syrup and hand whipped cream that they serve during the winter at Del Monicos- I know I know the ground is so hard during the winter- blah blah- we'll just have to have the package hollow out it's own delivery vault, if you know what I mean, my friend. I'm sure Cod got the heater core all patched up in the work car by now and popped on the snows. I can't remember; I hope we didn't accidentally use the tire chains on the last big fat heavy delivery from the boat, you know how that highway gets. I dunno why Mort insisted on storing them on the boat anyway. I guess it wouldn't hurt to stop by the marina or Joy Auto on the way outtta town--Hell----I'll even pick up the tab for a new set if we need 'em.
^^^Copyright ©️ 2020 3flushes Media.^^^
Return to “Orient”
